Why is it I seem to do the weird stuff in a drivetrain and subject area even you deem as "out there?"
1996 3.4 DOHC Monte donor.
I plan on dropping a manual trans from a 91-93 cavalier behind it.
Yanked all emissions and did some port and polish work on heads and intakes, deep as i could get with die-grinder.
Heard some rumor about 1995 dohc cams being better, so looking for a set if this is true.
Also, motor being cheap rebuild (re-ring) and I'll most likely time the cams with cam degree wheel, Ben, I see tons of posts on how too's with aftermarket and experimental tools, any for old school on the stand cam degree kits?
Last, do i have to go to obd 1 to run this motor with the manual trans?
And why haven't any of us made a windows OBD 2 reflasher to our specs yet?
Indy race teams did it all through the 90's, where is their software?
