I have a set of nicely ported heads begging to be installed. The car is due for e-testing in April I believe. This car doesn't play in the snow so ideally I want to start driving it again in April. I've been putting off installing the heads because I fear they may cause an emissions fail. The car has a high flow cat and that will be staying.
4 years ago it *almost* failed. 2 years ago it passed with flying colors. The ONLY change made was I discovered an absurd sixty something psi in the fuel rail! Clearly the rich condition caused the near failure.
It passed the last test with the EGR turned off and the 13* exhaust cams retard. Mind you, it passed this test with flying colors. I would have used the chip that has the EGR on, but for some reason it gets code 43 with that one.
So, I ask you, will these awesomely ported heads have a negative, positive, or none whatsoever impact?
In case you want to make a well informed decision, as it sits right now:
-91 3.4
-~120k miles
-2.5" cat back, hi-flow cat (magnaflow brand I believe)
-exhaust cams retarded 13 degrees
-96 intakes
-75mm TB and custom plenum arm
-WOT Chip (egr off, lean cruise on)
-91 3.4
-~120k miles
-96 intakes
