What is the best spk plug wire the stocks are aftermarket?
Sparksplugs wires
Magnecor are probably the best you can get, and they have a lifetime warranty to boot.-Brad-
Originally posted by cutlass supreme FE3 View Posti had magnecores but i find them so thick and the need for an independent ground for each wire.sigpic
Originally posted by cutlass supreme FE3 View Posti had magnecores but i find them so thick and the need for an independent ground for each wire.Last edited by Dave96z34; 12-16-2008, 12:20 AM.
Magnicore's here as well. Never had a single problem.Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
Or any plug at all for that madder. You can add a better ground between the battery and the cyl heads.
MSD coils come with a guarantee to fail. I have had 2 die on me completely. One running a MSD ignition system. Other under stock ignition system.
Sory man but thats to much work and money for no gain over a set of Magnicores. The Magnicore wire performance gain is debatable. Do you have an o-ring seal on the front spark plug boots? That's so that you don't have sand and water get down in the holes.
That has NOTHING to do with WHAT wires you use!!!!!!!!!
You could use wires from Hong Kong for all I care and it WILL NOT be the reason OR cause of what you have pictured above!
I have seen that coil picture a dozen times and NO OFFENCE
BUT
ANY COILS...
MSD
ACCEL
AEM
CHEAP AFTERMARKET
EVEN GM
YES, AC DELCO coils WILL do that which you have shown above IF DO NOT USE the seals provided by MSD and use dielectric grease on the conections.
I HAVE SEEN THE EXACT SAME THING happen, EVEN when the coils and adapters were installed right and the individual had pressure washed the engine and sprayed the front side of the coils and adapters!
99.9% of the time when I see something like that it's NOT a faulty product IF and I say IF! it was new, installed correctly AND came with ALL THE REQURIED HARDWARE.
I have seen this happen when they have been purchased USED and the seals are damaged, missing or miss-installed.
ONLY WATER OR CONDENSATION WOULD HAVE DONE WHAT YOU PICTURE ABOVE AND I CAN SEE FROM THE PICTURE:
- NO DIELECTRIC GREASE ON THE CONNECTIONS
- THE SEALS ON THE ADAPTERS HAVE BEEN EXCESSIVELY TRIMED
MSD will tell you the same thing IF you send the pictures to them.
Again Dave, NO OFFENCE, I'm not trying to start something, it just that what is shown IS NOT A PRODUCT FAULT!!!!!1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
The MSD Customer Service Line is:
(915) 855-7123
(7:00 am to 6:00 pm, mountain time, Monday - Friday)
There great to deal with.....1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
Originally posted by 91LQ1Lumina View PostI don't understand what you are saying here, since the wires go from the coil to the spark plug the plug is grounded though the block. What independent ground is needed??Last edited by cutlass supreme FE3; 01-01-2009, 10:53 AM.
HayesPerformance
I never once said the wire were at fault re read it! And the second failure that I don't have a pic of the other side of the coil blew a hole in the casing out word and started to burn. Like some one shot it with a 45.
