Hello everyone!
I did some searching over the past few days in the DOHC section here (thanks dialup, I probably could have done this in an afternoon on high speed) and I wanted to get some confirmation on what I have found in my searching of various threads on here about pistons and connecting rods, as well as ask a few questions.
Connecting Rods - Small block chevy rods that are 5.7" will work in the 3.4 provided they are i-beam rods. H-beam rods will have to be machined to fit due to clearance issues. The only other alternative is a "custom" rod from Pauter.
Questions:
1) which SBC rods are a direct fit? I've seen the 327 rods and the 5.7L rods being mentioned.
2) Using these rods with stock pistons will not change compression ratio assuming everything else is stock, correct?
3) Is the Pauter part number still CHV-230-539-1448F per another thread I found?
Pistons - The only "off the shelf" pistons available for this engine are from Speed Pro which are Hypereutectic (with coated skirts per one thread). A piston from another maker (e.g. CP, JE, etc) would be considered "custom" although CP does have the measurements of the piston on file if you want a forged set.
Questions:
1) Some of the threads I found on this subject are dated, has the piston availability changed? Based on going to various 3rd party websites it has not, but I want to make sure I didn't miss something.
2) One thread said that these (Speed Pro) pistons are suitable for 95% of rebuilds out there. Is this a consensus among the forum members?
Rotating Assembly Question:
The stock crank with SBC rods (assuming they are direct fit) and Speed Pro pistons make an adequate, if not stout, bottom end for the 3.4. Agree? Disagree?
Thanks in advance.
Questions:
Questions:
Thanks in advance.
