Anyone figured out how to make it bullet-proof?
  • Anyone figured out how to make it bullet-proof?
    I was planning on doing a turbo install on my 97 dohc (87 rebodied Fiero) and am thinking about ways to beef up the engine before putting the squeeze on it.
    I've already got the ARP rod end bolts and main cap bolts but would also like to replace the head bolts with ARP studs.
    Other items on the wish list would be lower compression forged pistons, stronger rods, forged steel crank, four bolt end caps, girdle etc.
    I've seen posts about trying different forged cranks and 3100 main caps but has anyone actually done it?
    Is there a proven list of parts that interchange from other engines that results in a stronger bottom end?
    I may have to pull my engine to repair a bad head gasket so it would be a perfect time for a highperf rebuild.
    I'm going with low compression forged pistons, forged rods, plus ARP studs. I'm not sure how much more can be easily done. Pauter made the rods and CP made the pistons. They should have these in their database now.
    Tim
    325 whp 350 lb-ft
      That's a great start! Hate to ask but what do would the set of pistons and rods go for? Since they're in the catolog now hopefully cheaper than a custom job.
      What compression are you planning on getting? Are the pistons for an overbore? What is the part number for the head studs? I was thinking that the L67 forged crank would be a possibility too. That only thing left would be the caps. The dohc two bolt caps would be the weak link I imagine. They don't look too strong.
      It would be great to get everything together in one package for the ultimate proven rebuild kit.
        The L67 is the 3800 so that crank is not an option. I don't recall who, but there is a Fiero member on Pennocks with a 400 hp turbocharged 3.4L DOHC Fiero and I do believe the engine is stock but well tuned.
        I don't believe adapting the 3xxx engines aluminum oil pan, windage tray and main caps would be very difficult aside from the align boring that would be needed afterwards as long as the bolt hole locations are the same. That should add quite a bit of integrity to the bottom end above stock. If you opt for high performance small block chevy rods which have been narrowed for use in the V6, and a piston change, try to make sure the end result is lighter than the items you are replacing, a balanced lighter assembly will buy you a lot more dependability at high revs over the long run as well as make more power.
        The piston and rod combination I'm planning for my fully forged engine build so far has reduced reciprocating weight by nearly 100 grams per piston and rod assembly. It's not a 3.4L but the principle is still the same, less weight = less stress.
          Hey Joseph. Did you ever check back with that guy about the "press-on" crank trigger wheel?
            Has anyone used the newer 3500 forged crank? I've read that aftermarket sbc forged rods maybe used as well.
            I guess maybe a better question would be if anyone has made enough power to actually break the bottom end?
              3500 crank is a great and inexpensive option. I'm not greatly familiar with the 3.4DOHC DIS trigger (unless it's the same as the other 60*'s), but as Driver_10 mentioned, the DIS wheel needs to be replaced with a 7x reluctor. The 3500 crank shares the main bore diameter with the rest of us, but has a larger 2.249" rod pin. John (Driver_10) is the first that I know of that is going to try a 3500 crank in an earlier engine.
                I dont think a crank is worth it.. I dont see the thing breaking.. I say get the SP aftermarket pistons with SB chevy rods (maybe a little bit shorter to lower compression). and youve got a solid bottom end that doesnt break the bank.
                  The pistons were $1050 and the rods were $1,176. They were one offs which included measuring some pistons and rods I sent in, so another run might be cheaper. The pistons were 20 thousandths over and had a compression ratio between 8.5:1 and 8.75:1.
                  Pauter forged rod part number: CHV-230-539-1448F
                  The CP pistons weighted 431 grams each. Sorry that I don't know the part number.
                  Tim
                  325 whp 350 lb-ft
                    Shorter rods to lower compression is the wrong way to go about it. Increasing the quench will actually cause more detonation.
                      Really? Ive heard of people doing that.. What if you have a TT setup with decked heads??
                        Jus because people have done it, doesn't make it a good idea. When you start to create a lot of space between the top of the piston and the bottom of the head, then you are creating surfaces that can interupt the combustion process. If it was such a good ide, don't you think they would make head gaskets thick enough (or spacers) to reduce compression?
                        The ideal situation for our motors is to have the piston ~.040" from the bottom of the head (slightly thicker than a business card). At full RPM, the rod will stretch and that number will shrink, forcing the combustion to happen inside the chamber, not around the edge of the cyl bore.
                          Im not saying one way or the other but i know the Honda guys have used thick head gaskets and alot of success for years. i know the L67 guys also have thick hg's as well to help lower compression... Like i said, i dunno enough about it to talk intelligently but i know it is done quite a bit... I know it would be ideal to have lower compression pistions rather then shorter rods or thicker gaskets, but it seems to work....
                          S
                          Shane "RedZMonte"
                          1992 Lumina Z34-VIRGIN (RIP)
                          1992 L67 Lumina Z34 (SOLD)
                          1990 Turbo Grand Prix (SOLD)
                            why lower the compression? there goes your out of boost power..
                            [SIGPIC]
                            12.268@117... 11's to come!
