My engine is ticking, and I'm about to tear it apart... more then likely on my spare time here this week. I'm afraid that I'm going to go overboard on this project... but we'll see. I have a hard time with restraint.
First some background. I own a race engine shop here in the Sacramento area (hiperfmachine.com), so designing the short block and porting the heads is no issue at all. I'm basically unlimited in resources.
How-ever, if I could get some leads on what works the best, that would help make this build as simple as possible.
First thing is simple. Do people have a proven cam grind for the stock lobes, and what cam cores I can use for making a custom grind? If any-one has a full set of specs off of some custom cams, it would save me a bunch of time.
How-ever, I'm not sure if I want to go with Turbo or Nitrous set up. Personally, I'm a huge fan of nitrous and run it on my vette. I love not having the power every second... only when I need it.
Should I switch to ODB II? I'm getting a strong feeling that we should lean on a big YES for that... If so, what cars should I look to rape for a ODB II system.. 96, 97 Z34's?
Plan on porting the heads, and so on... Does any-one have resources on springs, or SS valves?
The engine has already been bored 5mm over... is this block safe to go 10mm over?
Anyway, more questions to come. I will post progress of the tear down when it starts.
-Kyle
-Kyle
