ok i know i know.. another timing thread. but i've searched and couldn't find any answers.
Using a dial indicator or any other method to accurately measure/mark a depth, measure from the cam flat to the bolt head holding the cam carrier to the head. It is either this method or make a cam flat tool that will hold only 1 cam at a time.
(ok so i made camflat tool that will only hold one cam at a time)
so the timing belt gets installed here.....?
When you rotate the crank over 360 degrees, the cam might still move some. You will need to hold down the intake cam still or measure it since only the exhaust will be locked down during the intake cam timing
(so i put the 1 Cam flat tool on the intake cam? and the exhaust has the lock ring in already?? or is it still freewheeling?)
Rotate the crank 360 degrees to do the front exhaust cam. Install the lock ring and then pull the cam flat tool.
(i get that part)
Rotate the crank 347 degrees (watch the timing mark) and verify the rear intake cam is flat.
(of course it's flat it still has the 1 cam hold down tool on it correct?)
Install lock ring and hold the cam gear in place with the cam gear holder. Repeat for the front intake cam.
(ok so i rotate the crank 347 degrees from that point? or from the stock timing mark again?)
Now both banks are timed and its reinstall from here.
sorry for all the questions, but i don't wanna screw this up.
please help
thanks,
-canusa
(i get that part)
please help
thanks,
-canusa
