Do you have a way to monitor A/F ratio, or knock, any way to tune? Id be too scared to spray 100 without any timing retard or way to watch my A/F or knock. Start off with a 50 shot. Spray it a few times to make sure everything is kosher, bump it up to 75 and do the same. If everything is ok still, then go for the gold with the 100 shot.
I dont know what transmission you have, but my 4t45e wont shift if I spray through the gears. Even with shift pressures raised it wont. Ive got the nitrous cutting out so it can shift then it kicks back in.
