Lyle you have a PM
Custom Ground Cams
If anything less Vacuum would make the shifts a bit more firm on an Auto, but regardless if Vacuum gets too low your going to have Power Brake issues on either car.Originally posted by Davethe autos would need to have more vacuum then the manuals would.
--Dave67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
And the ECM will get cranky when it comes to tuning. I have seen Ben deal with such pushrods when tuning. They had pretty wild cams from what I have been told though.Originally posted by quantum110If anything less Vacuum would make the shifts a bit more firm on an Auto, but regardless if Vacuum gets too low your going to have Power Brake issues on either car.Originally posted by Davethe autos would need to have more vacuum then the manuals would.
--Dave-60v6's 2nd Jon M.
ok, so what wouuld be good cam specs? I am seriously thinking of ordering/buying them already cuz i have an itchy wallet (do i have the money, NO, but i got plenty 'o credit
seriously dont wanna order something for 500 and get shitty results....\"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
- FFP UD Pulley - FFP Chip - 8mm Taylor Wires
- 160* T/stat - Dual 40 Series Flowmasters
- Hi-Flo Cat
15.2@95mph - GTECH P/B
http://home.rgv.rr.com/tjperformance/Cap0005.mpg
Then there should just be this big NOTE on the homepage that says "NOTE: NOT recommended for autos! Not worth your time! Despire the HP gains, it's NOT worth losing the torque!"
Please. I keep reading everything won't work with an auto, or isn't worth it. I guess there is only one way to find this out....
I might have another cam grinder option. I was at Schneider cams the other day and I asked if they would be willing to grind a set of 3.4l DOHC cams. I was told that they "never turn anyone away". They said that they are involved in a bunch of weird projects. Their website is www.schneidercams.com
Its not up to me to decide what is worthwhile for you. I personally wouldnt bother with cams in an auto either. If you want to make your trans die faster, go for that top end power like the 5 speed guys. If I had an auto DOHC, I would be playing with the timing to increase low end and try to get peak power around 5500 and have it shift dead on at 6K. Only if I had a built up auto would I go for 7K. This is why I am not posting up every available cam spec...its pointless. Either you know what you are doing, or you ask a specific question about cam specs for your application. The guys doing the regrinds can also recommend something.Ben
I was told I would get more benifit from a 282 getrag swap than a whole plethera of mods. If i were to re-do my 4T60-E with a shift kit and a stall converter, what sort of specs should I be asking for?If I had an auto DOHC, I would be playing with the timing to increase low end and try to get peak power around 5500 and have it shift dead on at 6K.
