Hey guys, I want to build a torque plate to hone my block. I was wondering if making it out of mild steel will cause it not to work right. Because I know the off-the-shelf torque plates are cast. Also, is 1 inch plate steel thick enough, or should I go to 2 inch plate? Another thing, when it gets done does it have to be torqued on with a gasket in place? Oh, just one more thing. Do the cylinder holes have to be perfect, or could I slack off a bit grinding them to size. Any input on this would be great, thanks.
Lyle
Lyle
