Can i use the dremel on my block?
3.4c mods?? Want lots of N/A power
Originally posted by series8217 View PostUsing a cam gear puller on the 94-97 cogs will just break the cogs. The cogs should just fall off when you remove the cone locks. You can't really use a puller on the locks.-60v6's 2nd Jon M.
Alright Im working on my bottomend now. So far what I want to:
bore the block .030
remove casting flash
knife edge the crank
balance the crank
crank scraper
arp main studs
arp rod bolts
have the rods shot peened
what elso should I do while its down?
If your shop has a machine, shot peen the block when you're done removing all the casting flash and smoothing out oil drainback passages, before you have it bored and honed. My machinist shot peened my block and it turned out very nice. All of the rough casting finish is smoothed down and there are no longer any sharp edges anywhere.
Be wary of knife edging the crank. You can possibly remove too much material, to the point that it can't be balanced. Consult your machine shop.
Originally posted by gpchris View PostWhat exactly is shot peening?
The shot peening process for the block would be different than the rods; it doesn't necessarily need to be done with the same amount of force and consistency on the block as the rods. My shop had their own shot peening machine for cleaning iron blocks and stuff. I think it was more along the lines of a shot blaster but it did take down rough peaks on the casting and whatnot.
