best suspension setup and part numbers if possible
Been ages since I posted here... here is my set up (well all the suspension work I just did a few weeks back)
-Held Motorsports Front coil overs with 350lb springs
-Held Motorsports Rear coil overs with 300lb springs
-KYB GR2 struts all around
-Front and rear STBs
-Front ES poly sway bar bushings
-Rear C-maxx 7/8" sway bar with poly bushings (bar is identical to addco bar)
-Held Motorsports trailing arms with grease fittings
-Held motorsports lateral links with grease fittings
-PST front end kit including new ball joints, outer tie rod ends, and control arm bushings
-MOOG inner tie rod ends
The ride is great! Even with the hard spring rates. Its not a harsh ride believe it or not. The car hugs the corners a lot better, but I do need stickier tires, the tires I have right now can't keep up with the suspension and still tend to slide out from behind me when I push the car through a corner real hard. But even with the old tires, the change was phenomenal, I'd do it again in a heart beat!
I think thats it... total cost has yet to be calculated... I'm scared to, lol! My best guess is just shy of $2000 Canadian, and that would be including shipping and boarder fees.
