i want to rebuild my front suspension but don't want to use stock rubber bushings and i can't find any poly bushings for my front control arms. I was wondering if any body makes poly front control arm bushing for my 91 z34. who, what, and where
poly front control arm bushing?
68 El camino 454 speed muncie 3.90 posi 12 bolt,
80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
60 Impala 2 door hardtop L79-327 T56 4.11 posi.
83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
91 Z34 now has a hm284. and belly pan in the worksTags: None
They don't make them for the Gen I W-body. You have to measure and use universal ones.
I have ALL the aftermarket performance catalogs.
There are a few Poly bushing companys but none currently make them specially for the GM W-body Gen I1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
PST wanted to sell me a bushing set for 89-96 beretta which is screwed up cause the rear lower control bushing changed from a horizonal to a vertical in lick 92-93.
i'm probally just going to chuck some poly leaf spring bushings in my lathe and turn them and press them into shells. i did it for my buddies 64 rambler american with SBC, on the front suspension and the motor mount and they work great68 El camino 454 speed muncie 3.90 posi 12 bolt,
i'm just going to get some control arms from the junkyard and instead of pressing the original bushings out, i'm going pull out the tube for the bolt to go through and then hog out the rubber and turn down some leaf spring shackle bushings till they fit tight and use a poly based liquid nails to make sure that they won't move. no press or machine shop required, ya68 El camino 454 speed muncie 3.90 posi 12 bolt,
Originally posted by latemodelnewbee View Posti'm just going to get some control arms from the junkyard and instead of pressing the original bushings out, i'm going pull out the tube for the bolt to go through and then hog out the rubber and turn down some leaf spring shackle bushings till they fit tight and use a poly based liquid nails to make sure that they won't move. no press or machine shop required, ya
Why glue the bushings in? One of their best features is that they rotate in the shells; which means you DON'T have to have the suspension at normal ride height before torquing the bolts that go thru the bushings like you do with rubber bushings.
Use high-quality grease on the INSIDE and the OUTSIDE of the poly bushing or they can squeek. The supplier of the bushings will have a suitable lube; I'd expect 'em to include a couple of tubes with the bushings.^ some people may call this guy an asshole at times, but he isn't wrong very often -- Robert
