How to eliminate the a/c pulley
  • How to eliminate the a/c pulley
    Hello Im buiding a race only 3.4 dohc engine and want to get rid of the air condtioner what belt to use. thanks Norm
    well if it is race only, i would suggest going to an electric water pump and then u can just remove the a/c compressor, and u are probably going to remove the power steering pump as well. then that just leaves the alternator. maybe go to a junk yard and use a crank/alternator setup off of an older car.
