255
governor bypass/custom chip 94
Actually it has been off for over a year on the 91, I'm pretty sure, and probably close to a year on the 92, and both work fineOriginally posted by SappySE107in fact jon ran his all winter so far without that cover! haha
Hey Sappy, any more news on chip progress? If you get it to work, I would but one from you. I wouldn't mind a litle performance gain from the chip, but if it takes out the speed limiter, I am happy. Like you said why pay that kind of money for something that's not proven when I can bypass the limiter with your chip and spend that money on proven enhancements
-=Danny=-
sorry guys its my fault. my car is a POS and i am short of funds to finish buying parts. i am selling alot of shit but no biters. of course most of it is junk. here is my latest xtra. 94 uim, lim, and tb $15. or will trade for used rad or passenger cv joint. also i have a set of 96+ injectors $40. i have a 94 tq converter. nothing wrong with it i just upgraded to a stall while i have the crap out, just make an offer. i have alot of stuff for sale just make an offer.The Official Rotating Mass Nazi
is there any updates on the progression of hacking the 94-95 chips? I need vats turned off so my motor swap will run. Do 94-95 motors have passkey 1 or passkey 2?3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
Probably passkey 1, which IIRC would be a simple resistor pill in the key which the VATS module measures on startup. If it matches the one it is supposed to be, the ignition turns on, if not, no go.-60v6's 2nd Jon M.
Too bad GM only uses like 8 different ones so others can start your car up.
Was tried at one of the gatherings and people were starting others GM cars with other GM keys!
1995 Pontiac GTP
Over $12K invested, and still its slow. Maybe thats because thats most all repairs. Don\'t knock the engine though, because thats the only part that has seemed to last.
hey for those 96+ injectors, is that $40 for each one or $40 for all 6?
JakeGM Goodwrench Tech - GM Certified
Thanks for your work on this! I would be interested in this for EGR delete, rev limiters raised slightly, speed limiter removed, and the fans turned on sooner if possible.
325 whp 350 lb-ft
If you need someone to test out these chips for you, I definitely can. I'll have my car back in about a month. I don't need it as a daily driver. It isn't stock so fuel and ignition tables probably wouldn't be good things to test on it, but I would be game for anything else. It is currently running the BKLL code and is mechanically in great shape.
I am not new to aftermarket ECU tuning(having installed and tuned a TEC 3 and an AEM), but have never experimented with OEM. Having seen all of this information lately, I have been considering taking a shot at it myself. Right now, I'm reserching OBD1 scantools/dataloggers and wideband O2 sensors. Thanks again for your work on this platform!
325 whp 350 lb-ft
