3.4 DOHC Turbo
  • 3.4 DOHC Turbo
    I just finished up a 5 speed swap on my 1991 Z34 Lumina. I have to say what a huge diffrence that made. Its like a totaly diffrent car. Now I was really taking a close look at the 3.4 DOHC and it looks like it would not be that hard to put a turbo on this motor. There is a place for coolant lines and oil lines. I guess the big question is is that would this motor hold a turbo the way it is stock. And if it could how much boost could you run on it?? Has anyone ever doen this before to a 3.4 DOHC in a Z34 Lumina???
    read the other thread below this. a few people have done turbos on the cars.
      I have been running 10 psi on a completely stock motor. I'm at 168k miles now.
      Tim
      325 whp 350 lb-ft
        If you are thinking of going Boosted I have a Garrett T4, Greddy RS BOV, Greddy Turbo Timer, XSPower 38mm Wastgate w/dump pipe and a vortech 12:1 FMU for sale. $1100 total plus shipping.
        I dont know what this means but "ASS HATS" is funny
          And this will all work on my Z34 with the 3.4 DOHC
            check this out.
              Wow... Nice!
                That is an awfully small radiator:P
                  Very nice looking!
                  1999 Grand Prix SE 3100
                  1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
                  1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
                    what are you running for a UIM?
                    91 GTP HM-284 GONE
                    96 Special Edition LQ1/4T60E GONE
                    98 Spawn of Satan (L67 Regal)
                    87 V10 SM-465/Mild 350
                    06 Cobalt SS/SC GONE
                      went to the turbo shop today. looky.
                        Just Wanted To Say Thanks To Timg. He Has Helped Me Through This Whole Project.
                          Ooooo Soo clean! Im jealous! Should be a Very clean setup when done. I would recomend doing 42.5# injectors and ODBII when you are ready to run. Also i would recommend ceramic coating or heat wrap and a turbo blanket when its done. Makes ALOT of heat! I found some "Fire Sleave" heat sheild that slips over my fuel lines and protects them from heat. (titan motor sports makes a sweet turbo jacket). Also make sure then they add the wastegate that they add it at the Y where it collects or it could get boost creep.
                          Could you post all the details of your project (turbo size ect...).
                          S
                          Shane "RedZMonte"
                          1992 Lumina Z34-VIRGIN (RIP)
                          1992 L67 Lumina Z34 (SOLD)
                          1990 Turbo Grand Prix (SOLD)
                            I talked to the guys about the heat shield, and they said if i dont get it, it will melt my hood. The turbo is ceramic coated but I will be adding a turbo jacket. As far as the fuel lines. What did you do? The turbo I am running is a t04e 60 trim with a stage 3 turbine. For now I am going to run the 12.1 vortech fmu and then go back to the turbo shop and get mega squirt put in and tuned. Where can I get those injectors? By the way the shop is CFT. Central Florida Turbo.
                              they are running the wastegate at the end of the Y. TIMG told me that he gets boost creep because it is only one bank. What is boost creep? Same as turbo lag?
