Got a Zedder Lumina.. Somebody help me out here.
  • Got a Zedder Lumina.. Somebody help me out here.
    First of all, its going to be a project car... So what I am asking doesn't have to happen right away...
    1994 Chevy Z34.
    I want to make it go like hell!!!
    Here is what I thought of doing, don't be affraid to smack the hell outta me if I'm wrong.
    What I definitely want to do:
    -1 MSD DIS 4 PLUS
    -3 MSD COILS
    -3 MSD COIL INTERFACE ADAPTERS
    -8.5 MM SparkPlug Wires
    -Tranny Oil Cooler Mounted on the Front right of Air Dam (same size as Engine Oil Cooler)
    -Engine Oil Cooler Mounted on the Front Left of Air dam
    -95-96 Lower and Upper Intake
    -New Timing Belt
    -Milzey Header's (Said He will make for the 91-94 Lumer)
    -High Flow air intake (3" Steel Tubing, MAF Screen Removed, Scoop on Hood to force air in)
    -180* Thermostat
    Dreaming:
    -Bored out Cyl's
    -5 Speed (I had one once on a buddy's car, it flew like mad!)
    -Rims
    -Paint Job (Black Ground Effects, White Body, Black spoiler and hood luvers)
    * Exhaust
    * Turbo or NO2
    Done.
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      Zedder?
      '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
      '06 Dodge Magnum SXT 3.5L -- My Daily Driver
        id say save the money from the dis4, coils and interface blocks and have your heads ported
          No need to port intakes or heads when your cramming 10psi in. It will make more power and cost much less... Just a thought
          Example A.)
          Exibit B.)
          Subsection 1-alpha.)
          Click here to see Video
          Shane "RedZMonte"
            So Turboize? Won't cutting a scoop in the hood with a ram air intake force more air into my engine?? One again please do smack me if it is required
            I probably should have mentioned that I am on an extremely limited budget, can I not run to a scrap yard and rip a turbo out of a pontiac or something?
              no it wont.
              Something cool coming soon...
              96 LQ1!
                you can build a turbo kit for a couple grand. you will make more power the be less $$ and headach then rippn the car apart and porting everything expecially if you pay someone else to take the heads and whatnot out to port.
                Im running a T04E super 60, Tial 38mm Wastegate and custom x-over and custom Downpipe. 5psi i made 270hp and 250tq to the wheels on a otherwise stock car.
                S
                Shane "RedZMonte"
                  Anyhow all that modifying is going to have to wait, I ripped the thing apart today after discovering that when I smack the throttle quickly, the engine stumbles for .5 of a second then continues... I have an ass load of carbon and oil and a gritty residue in my intake plenum... Sorta made me angry.
                    Nice turbo. Mine should be done this month or so.
                      Originally posted by 93Oldsdroptop View Post
                      Zedder?
                      In some parts of the English-speaking world the letter "Z" is not pronounced "zee." It is pronounced "zed." So a Z34 Lumina might be informally referred to as a "Zedder."
                      He who dies with the most toys is still dead.
                        -1 MSD DIS 4 PLUS
                        -3 MSD COILS
                        TOTAL waste of money, if the stock system is working properly.
                        OK.
                        Have you verified that the trans fluid or engine oil is actually being overheated? Over-cooling is not good.
                        -New Timing Belt
                        YES! Pulleys too. $185 at a USA NAPA.
                        Don't know nothin' bout those headers.
                        Total waste of money. A scoop on the hood is likely to be in a low-pressure area and hurt performance. Most "cold air kits" are a ploy to separate you from your money.
                        -180* Thermostat
                        maybe.
                        Dreaming:
                        -Bored out Cyl's
                        Why, if they aren't worn out-of-round or tapered? Lots of expense, not much payback--about 1 hp per extra cubic inch.
                        That'd be Canada where "Decal" rhymes with "Speckle", if my guess is correct.
                          Really? Well, that is news to me. Never heard of that before.
                            to save your intake from getting all gumed up after you clean it, put a air filter with a small bottom glass bowl with a drain in the bottom, the same used on the output line used for body work on a shop air compressor and put it in the hose running from your crank case where your PCV was coming from and run it to the rest of the hose, through the PCV and into the intake port. It works wonders in keeping all the oily crap and grime out and still works great. You will have to empty the bowl once and a while, but big deal, Your intake stays nice and clean.
                            Regards,
                            Dave
                            1991 Grand Prix STE
                            3.4 DOHC
                            1 of 792 Produced
                            Extensive Mods Done
                            1991 Lumina Z34
                            3.4 DOHC
                            Getrag 284 5spd
                            1 of 30
                              Since I replaced my PCV valve, I have noticed that not as much crap is getting through. The old PCV valve had a whole lot of milky white stuff on it and it was pretty much jammed. My car was a wreck, somebody was using it to tow something, it has a tow bar on it, if anybody wants it let me know.
