If you've got a motor far enough apart where you can get to it, this is an easy upgrade that will improve your oil pressure to your cams and lifters. The oil distribution cover has an anti-drainback valve in it on the bottom side where it mates with the block:
It has two problems. 1) It's incredibly restrictive, and 2) most modern oil fileters have anti-drainback rings in them, so the valve isn't necesary. To remove it, just get a flat blade screwdriver inside it and pry it out. Once it's removed you can see the restriction and how much more room your oil has got to get to the top of the engine:
I recommend doing this if you're going to run oil heavier than 5W-30, or for anyone who's goin to run their motor a lot at high revs.
