is there a optional can setting for the dohc that will help the low end.. i know that the 13 retarded exhast really helps top end but hurts bottem end alittle... and was wondering it their was an opposit to that
low end for a DOHC
low end for a DOHC
1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
http://members.cardomain.com/mperkins442Tags: None
Just for hahas I knocked both cams foward a tooth and the engine gave me everything it had at the tap of the gas....but at 4800-power drops fast and there is no accelleration after 5000. Virtual wall.Lorenzo
maybe if someone wanted to get REAL creative..... and spend alot of $$ along the way... they use that system on their vortec inline 6's in the trailblazers, but only on the exhaust cam. Probobly don't have room to do a "conventional" setup to vary the cams. BUT, I'm sure someone out there is crazy enough if they wanted to do it, they would lol.1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
1962 Buick Electra 225 STOCK... and gonna keep it that way
Sappy's idea for a duel intake runner design would be easier to implement than variable cam timing...but still not for the weak of heart to design and undertake.
I'm gonna say, I believe any setting like that and you'd be engineering the engine against its design. 4 valve per cyl usually isn't supposed to have pushrod low end...not that it CANT, just its easier and more beneficial to work more on the mid/high...BUT supposedly Sappy's head work makes crazy low end.
I hear the 13 degree barely hurts the low end...Im sure if you've already gotten the basic basic mods (CAI, UD pully, and most important: Chip) it would be mostly unoticable
I guess you could just get a 5 spd
I don't know why everyone thinks the 5 speed has "crazy" low end. I haven't driven an auto DOHC, but if you guys aren't exaggerating the difference between the 5 speed and auto low-end... then damn do I feel sorry for you auto guys. Other than the better gearing I don't think there is a hell of a difference.
If I'm under about 2500RPM in first and mat it, it won't chirp the tires... but over 3000 or so in first or second... I've got crappy tires though.
Anyway, back to the question. I agree the only way to get good low-end results that I know of are the chip, UD Pulley, and CAI. At least as far as bolt-ons go.--Rob
Mine will all out burn em from punching it in first at any rpm above 1500.
The low end is not better on the 5-speed, just feels it in first becuz the gear is so much shorter than in the auto. And for racing, the 5-speed can just launch so much better off the line, it gets to 4k so much faster.
i arledy have a under drive pully chip 3100 stall converter and several other mods..... i was just asking a random question... i have good low end arledy.... it will light the tires up as is... but i was just wondering if any body had tryed any other timing seting other than 13 retard... wich im about to do to my car1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
Originally posted by blk92z34getragI don't know why everyone thinks the 5 speed has "crazy" low end. I haven't driven an auto DOHC, but if you guys aren't exaggerating the difference between the 5 speed and auto low-end... then damn do I feel sorry for you auto guys. Other than the better gearing I don't think there is a hell of a difference.
Anyway, back to the question. I agree the only way to get good low-end results that I know of are the chip, UD Pulley, and CAI. At least as far as bolt-ons go.Lorenzo
what? what he say? I thought headers where a GOOD thing\"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
- FFP UD Pulley - FFP Chip - 8mm Taylor Wires
- 160* T/stat - Dual 40 Series Flowmasters
- Hi-Flo Cat
15.2@95mph - GTECH P/B
http://home.rgv.rr.com/tjperformance/Cap0005.mpg
is their a way to do the rear headers on an auto car without cutting the frame1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
