NOSzle Nitrous Systems
  • NOSzle Nitrous Systems
    Has anyone seen this type of nitrous system? Seems like a really cool idea. Does any one know if the non nitrous fuel atomization would be hindered by installing this type of system. Next thing, will the universal 6 cylinder fit our cars? P/N 08006NOS What do you think? I found the price on the summit website. 1199.95USD
    Lyle
    I doubt the noszzles would fit under the inatke manfiold but noone has yet to try it so its hard to say. What happens is is that the fuel rail sits about a 1/2 an inch or so higher as the nozzles take up space. SO if you have enough room under your plenum for it then then yes you an use this kit.
    I would go with this kit but I am not in the mood to spend $1200 on a nitrous kit when mine works just fine for much less then half that. ultimately I would upgrade to that but I can't justify the price right now.
    SOmetimes you can find them on ebay for around $900 for the 6 cyl kit.
    And no it doesn not effect the spray pattern of the injector whennot on the bottle to caue a decrease in hp.
    Its a good design
      Would you get better results with this kit?
      Lyle
        Over using a single fogger kit? Yes you will get better results. More even distribution to each cylinder. And the ability to make more power with less nitrous.
        Like I said, I would get it as it would fit under my intake on my custom 2.8. I dont' have a stock upper plenum however so no idea if it would fit under a stock plenum, or even on the dohc plenum or what not. You will have to eyeball it and see how much room you have above your fuel rail to see if it will clear. I would get it but its too much money right now. It is pretty much the ultimate kit right now as far as distribution and performance.
          Thanks
          Lyle
