Originally posted by Lyle's GTP
AAAAAAAH! Phantom stalling again!
Dun dun dun..... I replaced my fuel filter (GOD was it rusty!), something I suggest everyone to do... Took all of 15 minutes with minimal fuel loss (unlike my camaro, which drown me in 1/2 gallon of fuel). Anywho, when I started it back up, I noticed what sounded like an air leak... I traced it back, and looks like it's coming from my brake booster hose, which is a little loose, and a *HUGE* vacuum leak from the EGR base area. I spray intake cleaner around it, and the rpm's jump like crazy! F#cking egr! I swear, this is like the 2nd gasket set I bought for it... Moral of the story: vacuum leaks are the devil. I bet this is where my idle miss was coming from. Now I just gotta figure out what to do about it... I think I need to have the hole welded shut.Okay now, that's enough of that.
Did you let it sit and let the ECM relearn how to run the engine all over again? If not, pull the ECM fuse for 10 seconds, put it back in, turn the ign. on for 5 seconds (don't start the engine), turn off for 5 sec., turn back on for 5 sec., and start, and let idle for about 10-15 minutes. Then drive around for a while to let the ECM relearn.-60v6's 2nd Jon M.
BTW, what color is the top of your injectors? The top 1/4 or so is grey on mine, which I have heard is the $700 injector option in question, and my car still stalled for a while there.-60v6's 2nd Jon M.
Originally posted by pocket-rocketDid you let it sit and let the ECM relearn how to run the engine all over again? If not, pull the ECM fuse for 10 seconds, put it back in, turn the ign. on for 5 seconds (don't start the engine), turn off for 5 sec., turn back on for 5 sec., and start, and let idle for about 10-15 minutes. Then drive around for a while to let the ECM relearn.Okay now, that's enough of that.
The ign. on/off is the IAC relearn, or idle relearn as some people call it. I do belive those are the same exact injectors in both of my cars. I might have time to take pics of both cars tomorrow, *might*. If I can, I will post them here.-60v6's 2nd Jon M.
Originally posted by pocket-rocketThe ign. on/off is the IAC relearn, or idle relearn as some people call it. I do belive those are the same exact injectors in both of my cars. I might have time to take pics of both cars tomorrow, *might*. If I can, I will post them here.Okay now, that's enough of that.
here is a ***GREAT*** article I just found offering some insight into perhaps why it stalls at closed throttle conditions!!!
What a stupid system... I bet that's why they changed to MAF in 94...Okay now, that's enough of that.
Originally posted by ryan.hessbtw - those new $700 injectors could look the same in every way, but have different internals... something to think about.-60v6's 2nd Jon M.
Originally posted by ryan.hesshere is a ***GREAT*** article I just found offering some insight into perhaps why it stalls at closed throttle conditions!!!
What a stupid system... I bet that's why they changed to MAF in 94...-60v6's 2nd Jon M.
Hey hess, have you had time to take it to your local GM dealer and let a "drivablity expert" ride w/ you? You'll save a lot of time and it's free. Took me about 20 min., I showed the guy the tsb for the injectors, told him everything we replaced, and he knew immediatly what the problem was. Save yourself some time.
