Belt broke. used the instructions found here to tear it down and now for the rebuild. if i'm not interested in changing the cam timing ... is it necessary to go thru all of the cam gear removal routine? Also, do you just install the cam hold downs on the flats and install the belt? I found paint marks on the cam gears and this is the confusing part.... with the flats of all four cams facing up and locked down .... two of the marks on the rear bank face each other while the front bank has them on the outside of each gear...... help me out what is the right way to get this thing back together...
Salmanman
91 lumina Z34 Red completely stock...
Salmanman
