idle surge when coasting at low speeds
  • idle surge when coasting at low speeds
    92 Cutlass Supreme 3.4 dohc . engine 199k miles xmission 100k miles. Engine starts and idles fine .Runs at highway speed ok . Shows egr code when letting off gas at highway speeds but has done that for 5 or 6 years and never had any problems before . When driving at low speed around 25 mph and let off gas , idle surges up and down approx. 1000 rpm for 3 or 4 times then returns to normal . Doesn`t do this all the time . Any ideas what is causing this ? Thanks for any Help
    maybe your egr has a leak to the outside air.
      yeah possible vaccum leak
        yeah if the egr is leaking or failing it will mess with it.... but that much of a shift in RPM makes me think intake leak... maybe thru the EGR Like said above.
