Ive had this horrible problem with the GP since I put the 3.4 in it over a year ago. In a nutshell, on cold starts it has zero low rpm idle resolution. When it idles or warms up, it will either be below 700rpm, or above 2500. It constantly revs way up, sometimes to 4000rpm, then drops down and almost cuts off. It does finally settle down after awhile, and with me nursing the gas a bit.. it will come down to 2000rpm or so. It still idles very rough when it does, like a huge lopy cam.
Anyway, after replacing everything known to man on this thing, it still does it. Yesterday I changed the oil after about 6 or 7 months. I only drive it to the bus stop up the road, and then back to home.. so maybe 2 miles per day. I noticed that the bottom of the engine was oily, something I vowed to not happen after I pulled out the 3.1. I couldnt figure out where it was coming from because I didnt see any area's of leak, the bottom half of the engine/trans was just washed with oil/dirt.
I traced it back up to the oil distribution area in the middle of the V, under the intake manifold. There are puddles of oil behind the distribution block, and it is not from the distributor shaft cap. Whats odd and probably related, when I pulled the plenum a few months ago to replace the injectors, oil literally poured out of the EGR base plate in the plenum. I have also caught a bit of blue smoke on startup which only lasts for a few seconds.
Heres the point of the thread: After changing the oil yesterday and letting it all drain out beforehand, it ran fine this morning.. like it should. It Idled perfectly, and there was no gap in lowrpm throttle at all.. very smooth. In the past it has also done this after letting the car sit for 4 or 5 days without driving it.
