I was hoping someone in here could help me out. I have a 97 Monte Carlo 3.4L DOHC. After it warms up it will buck slightly at idle and feels like a horrible miss under acceleration until 2500 rpm. It is good at first start up in the morning. It is very consistent. Also at a constant cruise under 2000 rpm it bucks. It will also do it out of any gear as long as the rpms fall below 2000. Once I get above 2500 it runs fine. I’m not getting any codes. Changed plugs (Autolite Plat.), wires (AC-Delco), Catalytic converter, fuel filter, Intake Manifold gasket, checked coil primary resistance and secondary, signal from control mod seems good. I will be changing the timing belt soon it’s a little over due. I was also wondering if it is alright to break the cam gear bolts loose while holding the cams with the cam flats tool? Had some suggestions about the EGR Valve might be sticking. If any one has any ideas it would be greatly appreciated.
Thanks
Thanks
