Camshaft Bearing
  • Camshaft Bearing
    1) Is the block oiling system the same for Pushrod and DOHC?
    2) Specifically, #2 camshaft (oil pump driveshaft) bearing was installed in what I think was the wrong position. Looks like the hole in the bearing should have been orientated to the hole at 12:00 on the block. I realize that there is a grove for the oil but the whole would not drain oil.
    3) I think there may be two different cam bearing sets for the different years....maybe they had oil flow issues. Is anyone 'porting' the oil passages.
    4) Anyone actually install these?
    95 MC Z34 Black
