And so-on....
1) Has anyone split a 91-93 intake in half to port and polish the runners (and have it TIG'd back together afterwards)? I can do lower intake on my own (but it's pretty close to where it needs to be)... I've never seen the inside of that upper... Does anyone have a cross-section handy? If it's never been done, I'd be willing to buy a junkie and chop it open myself to have a look... But if someone has pics, I can have some edumacated guesses made. If anyone has the intake just lying around and wants to sell it CHEAP for the greater good of our hobby... Shoot me a PM. I would be more than happy to explore this option (with flow-bench data) complete with pics and instructions. I'd also very seriously looking into tossing a larger throttle plate in if I'm already going this far. Actually, it'd be cool if I could figure out a way to turn this thing into a 2-peice intake by making a gasket for it, and dropping some long bolts through it to keep it together.... Maybe welding on a few bossess... Gee-willikers, batman! That would make it easy to test-and-tune... I'd have to get both surfaces planed level, though... But still... Worth thinking about, no?
The only disadvantage I can see is that there will be a welding seam running over the top of the intake that would have to get cleaned up, or else the imposition of some new bolts that would look a little out of place... And then there'd be that vertical slash near the throat of the throttle-body... I'm sure I can get it to seal, it just won't be as purty.
2) In terms of driveability, since this is no longer destined to be a daily-driven car, (and doesn't have to pass emmissions) what advantages would I have from removing the EGR on this motor? Besides the simplification of the EFI path (which is more or less enough as it is), do I have to worry about excessive combustion temperatures at cruise? I don't expect a horsepower gain at all... Ah hell, lemme rephrase: I'm not looking for a driveability GAIN... What I want to know is that do I lose any driveability by removing and sealing up the EGR setup.
