I originally had one uber-huge post... But for simplicity, I've broken it up.
The story goes that I've damaged my motor as outlined in my previous post. yada-yada-yada.
I'll either be rebuilding my exisitng motor, or else buying another 91-93 junkyard motor and rebuilding that. Depending on internal damage.
This post refers to questions I have about rebuilding pertaining specifically to the rotating assembly:
1) The motor will be stripped down to bare heads and bare block. The block will be sent out to be boiled, and bored. I'm not planning anything major in terms of an over-bore. 010 or 020 over just for wear repair. The crank and rods will be cleaned and checked, and machined. I'll probably have the whole assembly balanced at this point. New bearings for everyone! I'm also considering having the rods polished and peened. Anyone had any experience with this? I can do the polishing myself (I LOVE working with metal
), but I'll have a machine shop do the rest
2) Here's a big question: What are the INTERNAL differences on the rotating assembly between the AUTOMATIC motors and the MANUAL motors? I am running an "automatic" motor through a 4-speed manual with a hacked stock 92 ECM. I've heard all sorts of conjecture, but the one that keeps popping up is "Thrust Bearing." Since the manual transmission doesn't have a torque converter to absorb torque-shock spikes through the drive-line, it seems to me that I might be accelerating wear on the rotating assembly. Should I source out a manual crank for it? or can I modify the existing hardware?
3) The heads will be ported and polished. I'm getting some guidance on this from an old hotrod friend of mine (the machinist, actually). A pro port and polish will be quite expensive, so I'll probably just pay him to look over the heads, and get professional guidance. If by some stroke of luck my valve-train is still useable, I'll have the valves and seats machines, and I'll lap the valves myself. The machinist will deal with the valve-guides (knurling, new seats, whatever). I love playing with die-grinders, and the way I figure it, if I have some lessons from a pro (not to mention some flow-bench data) I can't lose![smile](https://www.60degreev6.com/vb5/core/images/smilies/smile.png)
4) The cams will likely have to be reground anyway, and since I now have a fuel-efficient beater, I'm seriously debating a better-than-stock profile change. I'm not convinced on the stock-cam timing "tricks" (13º retard, 8-8 etc)since nobody seems to have any data other than ass-o-meter speculation. Nor can I find any good cam info that I can plug into DTD2K3 to check the math. Anyone that has some info (dyno sheet for example) on this, or with any other cam change (commercial or custom, doesn't matter) can chime in now![smile](https://www.60degreev6.com/vb5/core/images/smilies/smile.png)
5) Piston selection will be tough. See, I'm seriously considering a turbo for this motor (nothing uber-fancy... Just a T-4 at 6-8psi), so I'll probably leave compression alone (or lower it a hair). I'd like lighter pistons, but am wary of hypereutectics since I hear they don't fare well under any kind of boost. Anyone have any experience with a decent forged piston?
![Mr. Green](https://www.60degreev6.com/vb5/core/images/smilies/icon_mrgreen.gif)
