Borrowing ShockTherapy's topic idea:
Attached are pictures of my timing belt. As I got the car 3+ yrs ago w/40k on it, I doubt it's ever been changed. The car has 65k now (95 Z34). I was planning to get the belt/tensioners changed at the dealer as I don't want to screw around with it myself, nor do I want to chance a shop timing it correctly.
How does the condition of the belt look? Mileage-wise, I'm due. Wear-wise, not sure.
***EDIT: Click images for larger hi-res versions***
Also, on the last pic, are the small yellow lines the timing marks? I assume in the pic that means the cams (at least the front bank) are timed correctly?
Thanks!
Thanks!
