RE: re missing 3.4
ok, the icms from canadian tire work ok, ive used one, i would still rather a gm one. when you did your crank sensor did you use a gm one? if not i would go back and get one. also take off your connector and make sure its not corroded or bent, i had the same probelm and i had a code 42, and it was my wire , it got jacked somehow changing the crank sensor, but it didnt happen until a few months later. check that out
Jake
Jake
