I had my crank sensor go one day and the car would not start. I've since replaced it but it has not run right since. It won't rev over 3000 without bogging and backfiring through the intake. I put a new ignition module on that I bought from canadaian tire ( not a delco ) and now it has a real bad ignition miss. I purchased a new delco ICM from GM for double the price and it won't start with that one in. It's like the plug wires are mixed up. I triple checked the firing order with no luck but as soon as I put the ICM from canadian tire back in it starts but with a miss and no power again (very weird).
Heres a list of the parts I've replaced since this started
Idle Air Control Valve
New Plug Wires
New MSD Coils
New Ignition Module ( I currently have three) original - non delco - delco
switched computer from 92 Lumina Z34
New fuel Filter
New Crank Sensor
Removed plenum and lower intake installed new gaskets to rule out vac leak
New Knock Sensor
New EEPROM for 3.4 40T60E
I had a shop do the cam timing. the back bank was off a couple degrees. They installed new generation cog wheels and set the timing up. There is little hesitation and the engine will rev up to 5,000 - 6,000 RPM now, but only if I really open up the throttle (sluggish to get there). The miss is still there at all RPM's and it still lacks power. If i hold the rev's at 3,000 RPM the miss is real bad. Also when I have the engine opened up at 5,000 RPM the RPM will slam down to 2,500 then back up to 5,000 like its getting choke slammed.
The only parts I have left to replace (besides the engine itself) are the TPS and the O2 sensor and I don't think they're gonna help.
The shop checked for vacum leaks and did a compression and fuel pressure check and their all good.
I initially extended the ICM harness to put it where the battery used to be and have since taken out the extended wiring (if you reroute the harness out where it usually travels it makes it with the original length). I've triple checked the wiring on this car all of it is exposed now. There are no broken circuits
If the engine backfires through the intake at 3500 RPM sometimes it will pull a code which is # 42 which according to my haynes book is :
Circuit or sytem : Electronic spark Timing (Ignition Control Circuit)
Probable Cause : Faulty Connections or Ignition Module
I think the problem may come from the fact that it won't start with a delco ICM but I don't know what's causing this.
Any help would be apreciated I love this car but it's driving me nuts.
New Plug Wires
New MSD Coils
New fuel Filter
New Crank Sensor
New Knock Sensor
