I think it goes down the side of the engine....
what is this plug?
I was thinking (hoping) that it is the low oil sensor plug.
wires are brown and white.
my oil lamp stays on during startup........
where the hell is that sensor, must be on the pan?,
maybe a pressure sensore plug on the block?95 MC Z34 Black
thats prolly the damn plug for the evap canister
or yes the p/s pump as my other g, car had a red connector for itsigpic
I didn't know the older ones had it too. Must have sume test purpose or gm would have wasted the $. But yeah I think I have seen a 97 with a ps fluid level sensor.Last edited by Dave96z34; 09-11-2006, 07:02 PM.
The plug was utilized on (at least) 1 Pontiac 1995 LQ1, it went into a sensor adapter on top of power steering pump.
Unrelated, the car also had the 2nd gear start switch.
I took the hood levours and will install onto my 95 MC Z34 hood.
I think there is another mystery plug on the drivers side as well, maybe for tuning or fuel pump?95 MC Z34 Black
Definetly the variable power steering setup. The 95 cutlass convertible has that power steering setup as well but I didn't know they had the wiring for it even if the car isn't equipped with that pump. Odd.
The red wire on the driver side is a test lead for the fuel pump (connect it to power, it runs the pump).Ben
