any1 know the part numbers for the distributor o-ring and the bearings for the balance shaft?
HELP ASAP need part numbers real quick
the distributer/oil pump drive o-ring is the same as the ohv motors.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
