prelube engine
  • prelube engine
    I am finally going to start the engine after its rebuild took me a year.
    Should I prelube the engine?
    Well I put assembly lube on everything, but I was wondering if I could get oil into the galley and bearings before I crank it over.
    I thought maybe spin the oil pump but I don't want to remove the head.
    I thought just tap into the oil pressure sending unit and pump into there.
    Or should I just start the baby up?
    95 MC Z34 Black
    RE: prelube engine
    If you put a good quality prelube on all moving parts you will be just fine. It only has to provide protection of a few seconds until your engine pumps up.
    Lyle
