Gear reduction starter for '91 - '95 3.4 DOHC
  • Gear reduction starter for '91 - '95 3.4 DOHC
    Which application GR starters will work for my 1992 motor?
    RE: Gear reduction starter for
    Come on. Someone must have put a gr starter on their motor.
      you looking for a stock GR starter from a later engine, or an aftermarket unit?
      '99 Z-28 - Weekend Driver
      '84 X-11 - Time and Money Pit
      Quote of the week:
      Originally posted by Aaron
        Re: RE: Gear reduction starter for
        Either would be fine. There are loads of things available for BB and SB Chevys and not much else in aftemarket. Any chance those fit a 60*V6?
        My main question is will a '96-'97 starter fit on my 1992?
          RE: Re: RE: Gear reduction starter for
          I belive that starters from all of the 3x00 engines with GR starters on FWD cars will fit... At least that's what I have been told. Hold on to your recipt just in case
            The late 3X00 starters are not gear reduction. They are a lot smaller than the early ones, but they are still direct drive. They used more efficient motors to make them smaller, but produce more torque than the early ones. The only difference I am aware of between the starters is the terminals are slightly different sizes, which might require some slight wire mods.
            I have read of people using the SBC starters, but I am not sure how much modification it takes to fit. Are you looking to the smaller starters to lose weight, or to increase cranking torque?
            Marty
            Quote of the week:
              the new style starters will work.
              Colin
                Re: RE: Re: RE: Gear reduction starter for
                Originally posted by v6h.o.
                The new style starters will work.
                Thanks, that's what I needed to know.
                Both are positives for me.
