Have any of you guys installed the Delco-Remy CS-130 type, 170 Amp "Iceberg" Alternator.?? I've just purchased it and was wondering if the harness connector is the same.
I'd also like to change the oxygen sensor while I have access to the 'rear' of the 3.4; does anyone know where it's located on the exhaust??
I've already changed out the knock sensor in the hopes it will fix the ignition problem I'm having.
It wouldn't start one day new Crank sensor got it running but now the engine has - no power, won't rev over 3200 RPM without knocking and backfiring, Bogs, misses and knocks under throttle,
Parts replaced in last month::
Idle Air Control Valve
New Plug Wires
New MSD Coils
New Ignition Module
switched computer from 92 Lumina Z34
New fuel Filter
New Crank Sensor
Removed plenum and lower intake installed new gaskets to rule out vac leak
New Knock Sensor (haven't started since I put this in)[/color]
1991 Pontiac Grand Prix GTP
Thanks
New Plug Wires
New MSD Coils
New Ignition Module
New fuel Filter
New Crank Sensor
Thanks
