Has anybody on here rebuilt a TDC or installed new rings? I have some questions about the ringset I bought and GM specs.
I test fitted my rings into the bores and am getting something like .015" gap on the top ring and roughly the same on the bottom ring. GM says that spec is .008-.018" on the top ring and like .022"-.032" on the second ring. It's a Sealed Power plain iron ringset with moly face topring for the later year style piston. I was under the impression that they were good to go out of the box, but I'm beginning to wonder about that. Also, my machinist mentioned that Silvolite pistons commonly recommends a wider top ring gap, as the hypereutectic alloy pistons tend to reflect more heat, causing the top ring to get hotter than ordinary cast pistons. I'm using Sealed Power hypereutectic pistons, and am curious if this is a factor here as well?
Be eternally grateful for any pointers, info, etc!
