Early this year my 94 3.4L started smoking on startup. Has 153K miles. It gradually has gotten worse. Burns a quart every 100 miles now. Can't see smoke very well when driving, but I'm sure it's burning oil all the time. Changed PCV already. The vacuum line that PCV valve is in always has oil in it. When I pull the PCV out, oil drips off it. At least SOME of my oil loss is going through that line. The line comes from the cover in the center of the top of the block (not sure what that cover is called.) I did a compression test. Results were high.....205-220psi. I figured it was high because of oil on top of the pistons. At least they were pretty close to eachother. I had a 'smoke test' done to see if the intake manifold was leaking. Someone told me that can cause it to consume oil. The shop said it tested OK. They did make a comment about not being able to get at the intake manifold very well. Makes me wonder if the test was very accurate. Anyway, I'm getting ready to take the heads off and take them in to have them gone through.......valve guides, etc. I figured that's what it probably is. What does everyone think? Any other ideas on what it could be? Should I pull the engine and get it re-ringed while I've got it apart? Lastly, the machine shop I spoke to about a re-ring said the sprockets on the ends of the cams have clutches in them. He said when those are taken off they have to be replaced.....they are one-time use parts. He said they're $300-$400 a set. I read through the Haynes manual and it doesn't say anything about replacing these when reassembling the cam carriers. Do these have to be replaced if I take them apart?
Thanks for any advice/help.
Denial
Denial
