bad gas mileage
  • bad gas mileage
    can anyone tell me why thase car car get bad gas mileage i have put new wires ,spark plugs, new fuel filter,air filter. havent average out the fuel mileage but it seems that iam getting less then 12 miles to the gallon . checked timing all is good changed o2 sensor also. wondering if the cat is causing the bad mileage ?
    Still delivering same power as usual? If not, and if lagging, coudl be ignition coil or module ..
    New member of 200,000 mile club as of May 16, 2005
      My fuel pressure reg . was bad when I bought my car. Just pull the hose off the fuel pressure regulator and cycle the key to check. If fuel comes out of the vacuum port its bad. It will run rich. Mine was still drivable. Shitty gas mileage though.
      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
        make sure your tire pressure is up to par. and no dragging brakes.
          wow 12 is bad - it must be running noticably bad
          might be worth doing a compression test also
            might be something simple as a bad egr valve
            killed the gas milage on our Z34
