The gauge reads maxed out at any rpm/engine load when the motor IS running. It also reads ZERO when the ignition is on and the motor ISNT running. Bad sender possibily? I figure it to be the sender because when the motor isnt running it reads ZERO and when the motor is running its maxed out indicating no fluctuation (basically an on/off switch now). Or am I totally off-base here?
Oil Pressure Gauge Pegged....
Re: Oil Pressure Gauge Pegged....
Originally posted by dykz34The gauge reads maxed out at any rpm/engine load when the motor IS running. It also reads ZERO when the ignition is on and the motor ISNT running. Bad sender possibily? I figure it to be the sender because when the motor isnt running it reads ZERO and when the motor is running its maxed out indicating no fluctuation (basically an on/off switch now). Or am I totally off-base here?1991 Grand Prix GTP LX9swap/Getrag 284 --- SOLD =(
1994 Corvette LT1/ZF6
2006 Dodge Dakota 4x4 3.7/42RLE
