All,
Ok so I redid the oring sealing, man I used the whole tube of copper sealent. and the thing still leaks...
Now I am lost. Checking out the page <http://www.brian89gp.com/images/engine/intake%20gasket/DSCF0028.JPG>
I am not sure what that thing is called in the middle, where it has a zig-zag pattern on it, but I was thinking that it could be leaking. What you all think ?
Also where else can the oil come up from ? If you are facing the front of the car, then it leaks right at the o-ring location and comes from the rear left. I can see it start to flow. It takes about 4 mintutes before it starts a constant drip, which may mean it pools up some place.
The only issue is when i take the lower off, coolent flys everywhere, and then i cannot trace back the oil leak.
Any ideas ? Help please....I know all of you are skilled !!
I am in plainfield, IL if anyone is near by...also what about some oil dye...can I get it at autozone ?
I dont really wanna pay the dealer if I can DIY....
thanks to all..
thanks to all..
