man my gremlins as of late are like flies. i kill one and 2 come back.
ok i eliminate all my gremlins, and go to my friends house. i got down on it twice and it is like a rocket now. anyway i pull up into his driveway and the car stalls and won't restart.
i popped the hood and there is oil everywhere. 1 major oil leak from the front valve cover and somehow the pcv valve got blown off. i lost about 2 quarts, 1 of them was in the plenum and intake tube assy.
i have done the following: replaced the plugs i thought they were oil fouled and the electrode was cracked on #3. checked the wires they are fine, checked the injectors, they are fine, plugged the pcv hose on both ends, swapped out the ign module and all 3 coilpacks, swapped out the MAF sensor, checked the timing belt/chain. the tps is working fine (.62 at 0% throttle angle) as is the iac and o2(around 400 mv), i tried spraying starting fluid in and nothing. i pulled the valve cover and it seems the cams are aligned but i haven't checked the physical timing yet. fuel pressure is adequate.
also smoke comes out of the intake and it smells like burnt gas, the source for most of it is the port on the front valve cover.
things i haven't tried yet but will: replced the pcv valve b/c i am pretty sure the original isn't any good, ad the 2 quarts of oil back just for the hell of it even though i don't think that is the problem, check the physical timing. maybe i might replace the cam sensor. is there any alignment for it or is it just a magnet like the crank sensor? check compression for the hell of it.
things that might be wrong that i might not do right now: crank sensor, ecm, and chip
any suggestions???????
