braking problem
  • braking problem
    latest quirk with my motor. under braking at low speed, the car will cut off.
    like if i slow down from 60 to 20 or less
    possible cause?
    i am thinking my iac needs to be tweaked a little. i noticed the stocker has a 1/8 or 1/16 hole in it and this one doesn't perhaps maybe that idle screw needs to be turned?
    RE: braking problem
    nevrmind i answered my own question. after many adjustments on the idle screw it is doing good on cruising but i haven't tried heavy braking again yet.
      moms bravada had a ruptured diaphram in the brake booster, when the brake pedal was depressed, the motor died, might be something to keep on eye on if the heavey braking death happens again.
        I had a very similar problem. It was the brake booster. I had a problem finding a junkyard one since I have a 92 and no other years fit. Anyways I paid 10 bucks and lucky enough it was the only thing left in the bay of the donor car. It only took about 30 min. to change. Hope that helps.
        Mike
        \'92 White Z34 - Custom Air Intake & Magnaflow Exhaust
          thanx. i will keep it in mind.
