Thought I previously found an explanation and listing of the diagnostic trouble codes for this car. Seems to have OBDII type plug, but with OBDI diagnostics (obviously), and only 3 pins in the connector (which don't match up with the generic code readers - special pattern, apparently). The post I remember reading talked about the "old" way to extract the codes (paper clip, and "service engine" light flashes - like some imports I've worked on), and had a link to a web-page with the full code listings and even a picture of the connector pins and bridging location. Can any of you kindly help with this? Finally getting close with this car, but this information would really help. Thanks.
'94 GTP - Trouble Codes
94 GTP - Diagnostic Codes
Found what I was looking for in another place. Maybe this will help somebody else. The site below's not bad for some things, but you'll have to enable pop-ups, if you have a blocker on your browser. Let me know what you think - appreciate any other help, especially with a prior post.
Website - http://autorepair.about.com/library/...l-dtcs-53a.htm
Thanks again.
