what kind of sealant with new water pump
  • what kind of sealant with new water pump
    i have red, blue and black....
    or just use the gasket solo?
    95 MC Z34 Black
    The gasket with the proper torque should work quite well. Just make sure the gasket surfaces are clean before you bolt it up.
    92 Lumina Z34
    Found coolant in the oil and metal in the filter.
    Also found a home in the engine compartment for a turbo and intercooler
    <a href=http://www.cardomain.com/memberpage/813554>Some pics at CarDomain</a>
      dry seal is the best way to go on a clean preped surface. Thread lock the bolts.
      I am back
      Mechanical/Service Technican
        I always used the blue non-hardening gasket sealant thats designed specificly for coolant gaskets.. I love the stuff - never had a leak since i started using it on cars 5 years ago
          Either have I.
          I am back
