How much oil does the 3.4 take?
  • How much oil does the 3.4 take?
    I have a 1991 Grand Prix GTP, with the 3.4l v6. I am in the middle of changing the oil, but I don't know how much to add. So how much oil does it take to fill it up? thx
    i added 5 quarts, but it still reads about 1 qt low?
    really? i think i only ever put 5 qts max into my 2.8, but the dohc motor has to pump it through more stuf, further to go and more to do for the oil so it makes sense you'd need more.
      6qts usually does it for my 3.4L DOHC
      New member of 200,000 mile club as of May 16, 2005
        wow fast reply.ok than i will put in another quart, ive just never had a enigne take any more than 5, and i was skeptical. thx again.
          5.5 Liters cold and drained down. Or 6 Liters warm and pumped up.
          You have an oil cooler though. So, definatily 6 Liters.
          Lyle
            ok thank you, iw ill add it tomorrow, and see how she runs.
              Depends on the size of the filter too.
              I am back
              Mechanical/Service Technican
                you dont have a dipstick?
                \'97 Monte Carlo Z34- Milzy Motorsports 2\" Headers, 2.5\" Mandrel Exhuast, Ported & Polished Upper & Lower Intakes, Ported Intermediate Arm, NGK TR55\'s, DHP PCM, 180* T-stat, EGR Delete, GM STB, GMPP Trailing Arms, & Coldz CAI w/ K&N cone.
                  No I don't have a dipstick, I was reading the oil level with a Thermal Imaging Camera
                    I just started laughing my ass off when I read that.
                    92 Lumina Z34
                    Found coolant in the oil and metal in the filter.
                    Also found a home in the engine compartment for a turbo and intercooler
                    <a href=http://www.cardomain.com/memberpage/813554>Some pics at CarDomain</a>
                      How much you pay for that there camera? :P 6 quarts totally empty. Normal filter. I change mine religiously. A case of GTX does it.... uh....(lemme cypher this)...Twice! Had to use the Abacus. (By the time this thread is done, it will be time for another oil change.)
