Hi Im wondering how many of you changed the gasket on the oil manifold while you were doing something about the O ring ? I pulled the intakes yesterday there was a deep puddle of oil all along the top of the block under the heads on both sides. Is the oil manifold usally leak ? does oil return from the heads past the lower intake gaskets ? motor ran fine but gaskets were crap i guess im having trouble picturing oil from the O ring laying next to the power steering pump
Exxon Valdeez Z34 more oil leak questions
RE: Exxon Valdeez Z34 more oil leak questions
Why the hell not change it if you got it apart? Im pretty sure mine was leaking when I tore the heads off to replace the head gaskets. You betcha I replaced every gasket I could.No leaks in 9 months(fingers crossed)2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
i have a 93 z34, the oil is leaking right on top of my alternator, how much is it to get the leak fixed???
email me: cavalier012882@yahoo.com
thanks
sara
