ok i was wondering what the easest way to replace the starter on the dohc is.... i put one in it before when i had the trans out.. but of course it was easy then cuz the subframe was out of the way..... and that starter is now giving me problems... and it has a life time warente so it is comming out
replacing the starter
1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
http://members.cardomain.com/mperkins442Tags: None
If its anything like a grand prix then it isnt easy, but I did it without taking out any anything except a couple of shields and the starter of course. I took off the wiring and shields. I also unbolted the starter from the engine. I found out that there is just enough space to fit it between the engine and the ac plumbing, but it is pretty tough to fit through there but at least it didnt involve taking out anything. To put the new starter in just put the process in reverse.1995 3.4 DOHC Grand Prix gtp
cold air intake, high flow cat, dynomax mufflers.
Originally posted by 93OldsdroptopIf your engine has the oil cooler assembly then that must also be dropped to get the starter out. Other than that, it's not too bad, in my opinion.
I have to remove the oil filter to get her out ..
When replacing .. some starters required shimmering, others didnt .. dont forget to check thatNew member of 200,000 mile club as of May 16, 2005
yea i used to oil filter trick on my 91 3.1........ that is probably what ill do this time too ....... almost time for an oil change any way1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
