i have a 91 lumina 3.1 i had just replaced sparkplugs and wires as well as an ignition module. and the car ran fine till one of the fans rubbed through one of my wires and the car started to missfire so i replaced it and it still does it. so i replaced one of the coils that the one wire got eaten through on. and still didnt fix the prob. does anybody have any clue what it could be or how i could see if everything is sparking thanks
car wants to die when giving it gas
Originally posted by pontiac92gpUse a timing light
doh! just looked at the dohc section from the forum mainpage and saw my name as the most recent post in all three sub categories. reminded me of aaron. lmao! <--literally1991 Grand Prix GTP LX9swap/Getrag 284 --- SOLD =(
1994 Corvette LT1/ZF6
2006 Dodge Dakota 4x4 3.7/42RLE
This is just a guess. Was your car stalling before you put in the new wires and plugs. I don't think your problem is with the wires, coils or plugs.
Check the fuel system, under hard acceleration if your fuel filter is clogged your get up and go will suffer. Possibly causing your car to stall.
Another idea your fuel pump might have possibly failed. No fuel pressure no gas no go. To change this though you have to drain and drop the fuel tank.
awe shuck\'s broke again.
