Have had my 95 Monte Z34 for a lil over 2 yrs now and still haven't figured out my problem yet. I have a small throttle tip-in hesitation. To start, i'll post what i've changed/done to "combat" the problem:
New tps, iac, rapidfire plugs, accel wires, fuel filter isn't too old, new upper and lower intake gaskets, new egr gaskets (done w/intake gasket change), new o2 sensor (obd1.5 only has one), no codes present. I've probably changed other things that i can't think of right now. Batt/alt are both new, just to throw that out there. I've also replaced some of the more accessible vacuum lines on the vehicle. What do you guys think could be causing this? In the 2+ yrs i've had my car, the stumble has stalled the car only twice, but when launching, it seriously kills my times. Are there any "hidden" vacuum lines that might be culprit to this? Also, would an egr valve w/a sticking solenoid do this? I checked the "plungers" on the bottom of the valve and they move freely, tho a bit carboned up. No codes are present nor are any stored. Thanks in advance for reading my long post. I've learned to live w/the hesitation long enough
![Mr. Green](https://www.60degreev6.com/vb5/core/images/smilies/icon_mrgreen.gif)
